SOURCE: how do i reset my
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
SOURCE: Distorted sound coming out of SW channel only
Yes ive heard of such a thing because just randomly my sx-316 decided to do that also
and im thinkin the amp is blown. my SW channel sounds as if its shorting yet ive checked all the wiring,polarities, and used 3 dif subs on it and all are the same result. The amp is built into the reciever so you cant modify the volts heading to the sub.
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
SOURCE: Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
SOURCE: Looking for replacement remote for Pioneer sx-205
The Pioneer SX-205 does not have remote control capabilities.
