Be sure to use a brand new needle. Check that the machine is threaded correctly. Also verify the bobbin is loaded (turning the right direction) and threaded properly. If it is still not stitching, it is very likely the machine has been knocked out of time. Take it for service.
I am not an expert on anything, least of all sewing machines...
The needle should carry the top thread under the table and make a loop that picks up the bottom thread from the shuttle and it is the interaction between the two threads with equal tension that creates the stitches.
The major activity of a sewing machine takes place under the table and in particular it is the timing of that activity in relation to the needle movements that is essential.
The timing is critical but mostly non-adjustable. I suggest you ensure below the table activity is actually taking place and then revisit the winding of the thread onto the shuttle reel and inserting it into the shuttle...
SOURCE: The needle thread is blocked
Threading instructions for similar brother model:
http://www.mastersewusa.com/masmag11901_files/b114_471_721_771_XL711S_info_tg.htm
Possibly lever is to keep bobbin in place? If so, should slide left/right over top of bobbin.
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
SOURCE: bobbin thread is breaking after a few stitches.
Hi Make sure the bobbin case is properly
installed or the bobbin thread will grab the top thread, wrap it around the
shuttle and then either jam or break the thread. Another possibility is the top
thread is catching on the thread spool top or wrapping around the spool pin.
Check the bobbin case and then re thread the machine (always with the presser
foot up). Then with the bobbin area cover open, hand walk a few stitches as you
watch the top thread feed from the spool and catch the bobbin thread to form
stitches. Be sure to use a scrap of fabric to catch the stitching. Please get back to us if you have further
query or else please accept the solution. Thanks for contacting fixya.com
SOURCE: singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
