Recently I've noticed that most of the screen will get the green dots. If I change the inputs it gets better, but still some remain, and they even jump around depending on what image is on the screen. the tv is a mitsubishi wd-73640 dlp
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
SOURCE: Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
SOURCE: samsung dlp tv. white dots scattered across the
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
SOURCE: How do I repair white dots/dead pixels on my 3
You have a bad light engine. It is available at encompassparts.com for retail price of $749.10. Call 1-800-638-3328. Consumer not in business could be higher price.
