Using some specific combinations of buttons, you can delete the old voicemail password and restart the phone. This will reset the password to factory settings, deleting your old password. Now, you can change the password to whatever you want. For any query or technical assistance, you can contact the Cisco customer care number. To get certified toll-free numbers, reach out the contactforhelp.com
Cisco Router Tech Support Phone Number 888 604 2301
On the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
create a new account:
set register back:
and that should let you login with bob/bob
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
SOURCE: user manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
SOURCE: ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
