I tried to change the speed censor and the speedometer, but it didn't work.
sometimes it work but most the time no.
thanx
It might be the part that goes directly to the transmission. Its right under the speed censor. It has two hoses attached to it, and three 10mm bolts. To remove it, first remove the cable attached to the speed sensor, then remove the two hoses (power steering fluid will spill), remove the three bolt, After that's off, you have to wiggle it out, which might be really hard because sometimes it comes out easy and sometimes it doesn't. This piece has a gear at the bottom that could have worn out, and replacing the top part alone might not solve the problem. Hope this helps, good luck.
P.S. when this is out, you cant drive the car.
