SOURCE: Frigidaire Affinity Error Code EFO
We got the same error. After searching countless forums, we found the solution! There were socks/underwear/change built up in the pump. The water was not cycling through properly. It didn't even get passed the wash cycle. Cleaned it out and everything works fine. Plus, the error code list is INSIDE the washer! Go figure.
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Hey friend, I appreciate your for the post!
I understand you are trying to disassemble your Frigidaire washer, ATF6000FS. I have researched your error code "E90" and that seems to be an issue with your main control board or user interface board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
The washer comes on and promptly displays error code E93, I looked in the manual, checked the wiring and they look good but do not have meter to check. I replaced control board as per the manual. It then sent out a code saying it was the user interface board, bought a new one of those and replaced it. Now it is showing the E93 code. It will not do anything but ding and display that error code. I have tried clearing out the code as well. It still just says E93.
Call the washer manufacturer (tech services) to find out exactly what the E93 code refers to. Having that will give you a bber chance at DIY. Could be referring to bad belt a common issue. But you have to find out for sure. Good luck
