2 cylinder 2 stroke
SOURCE: Installing GU2700XTST , I dropped a screw inside the pump area
Follow the series of pictures at: http://www.flickr.com/photos/appliancejunk/731287159/in/photostream/
SOURCE: Intake Manifold choke diaphram for 98 ford windstar
no you need the vacum hose that is what keeps persure on the acc.
SOURCE: knocking noise coming from air intake section on top of engine
The top section of the engine is called a '**** shell' there are baffles inside tha break away and knock. If you press down on this plastic section and the knock goes away. then you have to replace it. It unbolts usinh\g 10mm socket. You need a short one and a long one. also remove the IAC solenoid above the throttle body. **** shell is a dealer item only. also replace the gasket seal.
If the **** shell does'nt come, out gently use a pry bar between the throttle body and the cowl area, for more clearance.
SOURCE: 2008 Yahama 90 2 stroke outboard lower unit fluid leak
Ok by fluid I assume it is gear oil leaking yes?
There is every chance there is the smallest seal leak there that may only be present once the gear case gets a little pressure in it, either through use, or through expansion as the leg heats sitting in the sun even. Have you got a new washer installed under this screw to properly seal it? Usually a nylon type washer is best.
Also, how do you know the lower unit is not leaking or have water intrusion? Have you drained the gearbox oil recently? If so what color was the oil, milky looking at oil or good semi-transparent oil color?
SOURCE: Waverunner bogs down on acceleration
Our 1996 waverunner has been running great until this weekend. It seems to bog down after 3 minutes of running at full speed. If you keep it at 3/4 speed no problem, it runs steady. Tried carb cleaner but it still runs the same....What repairs are we looking at. thanks.....
