Did you ever consider checking manual for guidance? It is very clear regarding correct fluid level. Read it.
Sure I read the manual! The problem is that when the dip stick is removed, whipped off, replaced properly and removed again to read it is dripping with oil from top to bottom obscuring an accurate reading at the two holes even after the mower is sitting idle for some time
If U introduce the stick in very slowly and nice and straight into the opening, you will get a reading provided you wipe the stick nice and clean before introduction. I know it is a PIA but how else can you do it?
