Computers & Internet Logo
Anonymous Posted on Aug 27, 2017
How do I remove multiple phone icons from the screen of my ZTE cell phone?
When I click on one of the icons the same contact appears, if it opens at all.
5 Related Answers
Anonymous
  • Posted on Mar 20, 2008
SOURCE: u990 viewety
How do i stop the phone from locking it self so quickly. Can the time be delayed on the keypad lock. If so how ? As I dont wasnt to completely turn it off.
Anonymous
  • Posted on Dec 14, 2008
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
Sheikhtijani
Shehu Pro
  • 1284 Answers
  • Posted on Jan 07, 2010
SOURCE: bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
Anonymous
  • Posted on Aug 16, 2011
SOURCE: regarding touch screen
touch screen is not working properly. means when i click on start icon watch appears. and when i click on contact icon another program open. ok icon is not working
plz help me out. my phone is w8 sony ericsson
pabitra mahato
  • 355 Answers
  • Posted on Jan 15, 2012
SOURCE: Can't download mms on my zte score cell phone from
Ask your service provider for activating mms and mms settings. activate the service and settings and you will receive mms. enjoy !
please vote me if you are satisfied with my solution.
How do I block numbers on a ZTE N817 Android phone?
  1. From any Home screen, tap the All apps icon.
  2. Tap Contacts.
  3. Tap the name of the contact you want to block.
  4. Tap the Menu icon.
  5. Tap to select All calls to Voicemail.
How do I move files are apps to my SD card on a ZTE N9516
To perform the steps below, a SD / Memory Card must be installed.
From a Home screen, navigate: Apps Apps icon > File Manager.
Tap the category where the file is stored (e.g., images, Music, Downloads, etc.).
Touch and hold the desired file.
Tap the Move icon.
Note Multiple files can be moved at the same time; selected when a checkmark is present.
Move icon
Tap the Back arrow (upper-left).
Tap SD / Memory Card.
Tap the desired destination folder then tap PASTE.
Note The available folder names may vary.
Repeat steps as needed for addtional files
Unock a zte google account lock
Add
Tap Email .
If no accounts are configured:
Enter the username and password.
Tap Next .
Follow the on-screen instructions.
If other accounts are configured:
Tap the Menu icon.
Tap Settings .
Tap Add an account .
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Delete
Tap Settings .
Under Accounts , tap the account type that you want to remove (for example, Google).
Tap the name of the account you want to remove.
Tap the Menu icon.
Tap Remove account .
Tap Remove account to confirm.
if you not get any solution please go the :-https://support.t-mobile.com/docs/DOC-27449 and ask your query
Note:-Need the ZTE network unlock code just get in one click only
Official Zte IMEI Permanent Unlock Important Select the Current Network...
https://www.unlockninja.com/unlock-zte+phone
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Delete
Tap Settings .
Tap the Menu icon.
2answers
Cant switch my camera from front facing to rear facing on my zte paragon
In the default camera app the Switch Camera icon appears on the right (portrait) or top (landscape) of the screen. In my version of Android it looks like a camera over an arrow disc, but in older versions looks like an old style camera with a circular arrow where the lens would be. Tap it and your view should toggle between front and back
How to unlock screen on a zte touchscreen cell phone
http://xte.com.ca/
it's a long depress of unlock button and then 5 icons appear and circle.
this is your access.
Zte merit z990g does not show icon or sound, message alert
For Message alert first,you should build a folder named notifications and copy the ringtones that you want to use to the folder second,enter into message interface, click Menu key, click (setting), and (Select ringtone) interface will appear, then you can (set message ringtone) by selecting ringtone.If you are still facing difficulties finding a solution contact ZTE they will walk you through the process.
How do you send a text message using contacts
Go into your contacts .... touch the icon to the left, this may be the default droid picture ..... a pop will come up with options, click the icon that has a conversation balloon with a smiley face .... voila you can send a text message
or .... in contacts, touch the contact name your wanting to text. A screen will appear with all the contacts information ... the same conversation balloon with smiley face appears next to the phone icon .... press it
type to compose, and touch send :O)
3answers
I just bought a ZTE A35 and the manuel is in
Click here, you can download the file as a PDF, but it will make you sit and wait for the 20 seconds to count down before the download link appears. Don't worry though, this is normal:
ZTE A35 Manual
Goog luck!
EJ
Sep 29, 2009 • Cell Phones
2answers
Regarding touch screen
hi thanks for using fixya!
What is the model and brand of your phone/PDA?
Mar 26, 2009 • Cell Phones
Top ZTE Computers & Internet Experts
k24674
Are you a ZTE Computer and Internet Expert? Answer questions, earn points and help others
