SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
SOURCE: YAMAHA 2001 40 HP NOT PUMPING WATER,PUT OUTBOARD
Hi, it needs to have the water pump overhauled and it is not something you should attempt on your own. Take it to someone experienced to have it done correctly. Regards Phil.
