Need help with an acceleration problem on a 2002 Yamaha v star 650 idles great but when throttle twisted it seems to sputter and hesitate but runs decent when driving with the choke on
SOURCE: 2005 650 V star won't idle
i would say its either drawing air or the carbs need setup. You have to check the breather pipes and the rubber manifolds for cracks or splits.
if carbs need setup, then its best taking it to a good garage, to have them balanced and adjusted.
TL
SOURCE: how to lower the idle on a 2002 yamaha 650 v-star classic?
under the left side of the gas tank you will see i black knob/screw at the end of what looks like a hose. the knob faces the rear of bike. that adjusts the idle. its real easy to find and the only adjustment you can make to the carbs.
SOURCE: Yamaha v star 650 runs with choke on only
That is the problem,You need to clean the carb jets and get the gum out of the bowl.
SOURCE: 82 yamaha maxim 650 engine is hard to start cold
weak mixture,dirty fuel,air leaks on induction manifolds,jets blocked,fuel tap filter chocked,float needles sticking,fuel level in carb incorrect,thottles not opening together,air leaks at exhaust pipe joints,
Try cleaning the Mass airflow sensor and replacing the air filter. You can buy the spray MAF sensor cleaner from any auto parts store for about $6.00, ask the parts guy how to use it.
