SOURCE: peavey minx 110 no sound from main speaker but
Inside the headphone jack is a built in switching mechanism. It is there to cut off the sound to the speaker when you are using headphones to practice quietly. For some reason or another it seems as if this is no longer working correctly. One of the causes of this can be bad solder joints on the circuit board where this jack is located. Another cause is a failure of the jack itself. If you are capable, Take the circuit board out and have a look. Hope this helps.
SOURCE: peavey minx 110 no output to speaker-headphone
LOUD SPEAKER BURNED REPLACE
FREDDY
TIGER ELECTRONICS LTD
ISRAEL
