SOURCE: LCD blank & No picture taken
This appears to be a well known CCD problem, which Nikon acknowledges only for the COOLPIX 3100, 5700 and SQ models. Nikon denies the CCD problems on the 5400 are related, even though a Google search for this problem returns numerous results which claim the same defective Sony CCD sensor was used in the 5400 as was used in the 3100, 5700, and SQ models. See this reference: http://www.stevesforums.com/forums/view_topic.php?id=65777&forum_id=21
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
I had the same problem with my CoolPix5400 and this resolved the issue.
SOURCE: Blank LCD screen
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
SOURCE: no picture display when taking shot. Blank pictures produced when shot taken.
Solution:
Ebay has used cameras (DX4530) for about $75.00 with shipping. Kodak's repair service for these cameras is done by mailing in the camera -- and the baseline starting price is about $140.
I'm planning to go to Ebay and buying from a seller with a good track record and reputation.
SOURCE: Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
