SOURCE: speedstream 6520 wireless gateway not working
I deal with these routers on a daily basis w/ Frontier. Likley the radio is getting hott and its starting to burn out.. Put your hand on the radio, see if its running rather hott. If it is, unplugg it for an hour. If your a frontier customer, call tech support, get it replaced!
SOURCE: toshiba laptop A25 integrated ethernet and wireless lan not working
Right, you need to click
>Start
>Computer
>Vista C
>Toshiba
>Drivers
>WLAN
>Realtek
Then find a file called Setup, there may be several. You are looking for the one which is an Application. Mine is around 450kb in size.
Double click it to correctly install the Wireless adapter.
Follow the instructions on screen. This should take no more than 90 seconds from start to finish.
Good Luck
SOURCE: best way to network a HP LaserJet 4L with 2-wire gateway?
If you want to hook up the printer directly to your wireless gateway, you could get a print server. They are made for usb or parallel printers and run about $40 to $70 for a single printer hookup. Run the software that comes w/ it to create network settings and for installation.
SOURCE: WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
