Question about Smart Computers & Internet
I have a Kogan smart tv and i want Netflix it says your Netflix is set up and ready now stopped
  • 753 Answers
I did a google search and it said that Kogan TV's do not come with the netflix app pre-installed, you have to install it yourself, then login to netflix to use it. Try a google search and it will tell you how to do this
Posted on Aug 26, 2017
  • warner45w
    warner45w Nov 08, 2019
    An allergy refers to a sensitivity of our immune system towards some substance, which produces respiratory, digestive, nervous or skin alterations.
    upsers |
    www.upsers.com |
    upserscom
6ya staff
SOURCE:
Ben Worters
  • 58 Answers
SOURCE: hi... I have a Kogan Agora Smart TV,... the date
What is the model number on the back of your TV? It should look something like this KALED42SMTWA or KALED423DSMTZA. However, try the following instructions first, if they don't work I will need the exact model to give more specifics.
  1. On the remote with the TV turned on and connected to the internet then Press MENU button to display the OSD menu.
  2. Use left/right arrow buttons to select the main menu(I think the time should be 4th right from the top so that's 4 right arrows), and press down arrow button to enter the submenu.
  3. Check the time zone option first, make sure this is correct. You should be able to change the time in this mode, if you can't then it gets the time from the internet and the only thing you can change is the time zone and this should fix it as it will auto update the time from the net on its own.
  4. Press MENU button again to return to the main menu then press EXIT button.
I hope this helps..
Posted on Sep 07, 2013
SOURCE: netflix problems
maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
Posted on Jan 18, 2014
ist3alth
John Myers
  • 20 Answers
SOURCE: We bought this tv because
Its not your TV its Netflix. Go to Netflix Watch TV Shows Online Watch Movies Online and find the support link.
Posted on Mar 08, 2014
v6boyo
Paul Williams
  • 83 Answers
SOURCE: how do I get netflix. I have an RCA flat screen tv and a Samsung smart tv, I would like to get netflix on both.
You can buy a Blu ray player that has net flex on it. Then what ever TV you hook the player to you will have net flex but, you have to pay a monthly bill for net flex.
Posted on Oct 20, 2014
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: I NEED MY NETFLIX BACK. I HAVE A SMART TV KDL-48W650D
Lourdes, contact Netflix, they may be able to resolve your issue with software update or something from their end. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://help.netflix.com/en/node/96
How to fix Netflix not loading on smart TV
How To Improve Netflix Streaming On Any Device
Posted on Aug 19, 2016
I cannoton get netflix on our tv.
The Netflix app is available on many Smart TVs, game consoles, streaming media players, set-top boxes, and Blu-ray players. You can find more information about compatible devices and brands at devices.netflix.com, or read on to see if your TV is already Netflix-ready!
Dec 12, 2017 | Computers & Internet
I have a new house next door to my previous one that I had Netflix. I hooked up to internet have cable etc but can't get Netflix on my tv please help!
hi Jonel.
see if this helps you out.
Method 2 Smart TV
  1. Determine if your TV is a Smart TV. Smart TVs connect to your home network, and can run media streaming apps such as Netflix. ...
  2. Connect your Smart TV to your home network. ...
  3. Open your Smart TV apps. ...
  4. Select the Netflix app. ...
  5. Log in with your Netflix account. ...
  6. Browse using your remote.
6 Simple Ways to Watch Netflix on TV - wikiHow
How do you set up Netflix on TV?
Connect your Internet-ready television either with an Ethernet cable or wirelessly to your router. Follow the steps on the television to connect it wirelessly. 2. Select theNetflix Apply from the menu on the television screen.
How to Set Up Netflix Streaming for a TV ' Chron.com
smallbusiness.chron.com/set-up-netflix-streaming-tv-27369.html Search for: How do you set up Netflix on TV?
if this does not help go to this link might help you.
how to get netflix on my tv Google Search
Nov 26, 2017 | Internet Computers & Internet
Set up Netflix on my smart tv
select netflix with your remote...then login if you have an account or create an account with your remote
Nov 04, 2017 | Smart Computers & Internet
I have no sound on my new Kogan TV // DVD
Hello Lynne Dunn,
Since you specified NO MODEL NUMBER... I selected
a FIRST AVAILABLE full function Smart TV for you...
Look at the attached page
Kogan KALED553DSMTZA User Manual Page 35
To determine what setting you should select to
TURN ON your appropriate SOUND feature...
(page 35)...
If this fails to clear up your trouble... read furtherr
to TROUBLE resolution...(click here)
Kogan KALED553DSMTZA User Manual Troubleshooting
ELSE
You might need to call CUSTOMER support
for your consumer protectios for
a NEW (defective) appliance return process
Hope this helps
Carnac the Magnificent
Sep 05, 2017 | Televison & Video
Im all ready a member need you to down load netflix to my tv
Hello
Just follow these steps:
1.Determine if your TV is a Smart TV. Smart TVs connect to your home network, and can run media streaming apps such as Netflix.
2.Connect your Smart TV to your home network.
3.Open your Smart TV apps.
4.Select the Netflix app.
5.Log in with your Netflix account.
6.Browse using your remote.
For any help or support just visit us: Netflix Activate
Mar 15, 2017 | Netflix
How do I get Netflix on my tv
First you need a Netflix account. Then, if you have a smart TV, it needs to be connected to the internet and have the Netflix app. If your TV is not smart, your DVD player probably has Netflix on it and that needs to be connected to the internet. Then you have to log into Netflix on your computer and authorize the new device. They will give you an activation code to enter on the device.
Feb 13, 2015 | Samsung Televison & Video
How do I download Netflix on my Orion TV?
Is it a Smart TV? It has to be, then you press the Smart Button on the Remote and go to Apps, download Netflix which you may find is ready installed. Then set up your account details.
Sep 18, 2014 | Orion Televison & Video
Watch netflix with samsung TV
Hi , It is easy to have bbc iplayer or UK or US netflix on Samsung smart TV and watch it outside the UK or US
there are two way to do , one is using DNS ,, but no recommended because it blocked occasionally, so the best way is use reliable VPN provider which you can get from this link http://www.overplay.net/#a_aid=vpnprovider
you can get the account and pay for one month 10 $ or one Year 100 $ VPN + smart DNS , also you can ask for refund if not work for you so you are in safe side!
after getting your account ready , you need VPN Router , and technology of VPN better should be openvpn it is faster more stable than pptp or l2tp because it reconnect if even your main connection drop and restored
once your VPN router is ready , just reset your samsung TV to factory default , you can go to TV manual and do it
connect your TV directly to the VPN Router for your reference connection should be like below
Main Internet Router -----> VPN Router ------> TV
restart your TV and live it for 30 minutes ! vola you will see netflix , Pandoora , Spotify will apear on TV apps , just enter your user name password of netflix and start enjoying it !!! let me know if this helps?
May 22, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Computers & Internet Logo
1,413 people viewed this question
Top Smart Computers & Internet Experts
Julian Wainwright
Marvin
Marvin
pawnpower
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
