SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
SOURCE: Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. [email protected]
SOURCE: Need to replace working parts , push button , one piece toilet
Here is a link to a site with a ton of replacement parts for amstan toilets.
Without model numbers etc. its hard to know exactly what parts you need but you should be able to look at the pictures on the site and order the right parts...
http://www.plumbingsupply.com/amstan.html
HOpe that helps...
SOURCE: Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
