There is no kit and if you don't know how to test and repair this type of electronics then you need to take it to a repair shop. Polk charges around $250 for the repair.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
SOURCE: Husqvarna Viking #1 blown fuse
Contact Ron at A1, he sells Husq Viking and can even email attach a PDF parts list to you.
http://www.a1sewingmachine.com/parts.html
SOURCE: keeps blowing the fuse.
In more rare scenarios the 24v activated fan relay that is soldered to the circuit board can cause this same problem. I agree with Therinnaiguy, If the fuse is blown 90+% of the time there is a short in the 24 volt control system.
SOURCE: Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
SOURCE: Polk Audio PSW350 Subwoofer keep blowing the fuse
The brown resin is glue that changed color due to heat and age. Rarely have I seen it cause problems. So unless you are having problems, No.
SOURCE: Please help! Jamo SUB 300
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
