SOURCE: need programming methods and codes for sony tv
Have a look around in this site; http://remotes.com/store/codes_original.html let me know if it helps
SOURCE: just purchased RCA HD Tv. What is the RCA code
We would be happy to help you with getting your DISH Network remote to control your RCA TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your RCA TV here are some of the codes we currently have: 503, 627, 633, 725, and 505. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your RCA TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
SOURCE: Need program code for a RCA TV and a steren four device remote
You want to know the setup codes and synchronising procedure I assumes.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
All these details are given. Code list for RCA and synchronising proceedings are give in detail. Pull up older posts there.
SOURCE: code for soniq smart tv for remote control
038,029,036,022,055. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
SOURCE: How do I get activation code for Netflix for my rca smart tv
OK, what you are going to do is sign in to Netflix on your TV. It will give you a code, open your PC and go to: netflix.com/activate
(If you want just copy and paste the link)
If you haven't sign in by way of the computer, it will prompt you to.
After signing in enter the code in the space.
You should be good to go.
