SOURCE: Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
SOURCE: Laptop won't startup properly
Friend that problem if cause of not shutting down properly.just select start safe mode as it recovers it will restore late back to the proper one
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
SOURCE: black screen folowing options. safe mode etc. asus Eee pc 904hd
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
SOURCE: When Windows XP tries to load, I get the following
Enter in "Last known good configuration.
Then Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" .
Then right click on my computer icon click on property then click on hardware tab then click on "hardware profile tab"
Then select another profile is there is 2 profiles then apply and check but if there is only 1 profile then you need to create new profile with below method.
Click Start, click Control Panel, click Performance and Maintenance, and then click System.
On the Hardware tab, click Hardware Profiles.
In the Available hardware profiles box, click Docked Profile or Undocked Profile, and then click Copy.
Type a name for the new hardware profile, and then click OK.
Click the new profile, click Properties, select the This is a portable computer check box, and then select the best description for the profile (the docking state for the profile).
Click Always include this profile when Windows starts.
Let me know if you need further assistance. Thanks for using FixYa.
Step 1: Enter Safe Mode
a)
Start or re-start your computer.
b)
Before the Windows 7 loading screen appears, Press 'F8? to enter
Advanced Boot Options.
c)
Use arrows to choose 'Safe Mode' when you can see the Advanced Boot
Options screen.
d)
Press 'Enter' and wait for Windows 7 files to load.
e)
Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the
Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe
Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3
options are all available for you. Here above we take Safe Mode as an example,
but if you choose Safe Mode with Command Prompt, you'll need to input related
to command prompt to reset the password.
Step 2: Reset the forgotten Windows login
password in Windows 7
Now you could diagnose and solve some serious
computer problems in the safe mode and reset the forgotten Windows login
password in Windows 7 as follows:
1.
Click 'Start' button, input 'lusrmgr.msc' into the Search box and press
'Enter'.
2.
In the 'Local Users and Groups screen', click 'Users'.
3.
Right-click the account that you need to reset the password for, and
then click 'Set Password'.
4.
Type and confirm the new password, click 'OK'. (You can go to 'Local
Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on
desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
a)
b)
c)
Options screen.
d)
e)
1.
'Enter'.
2.
3.
4.
desktop.)
