Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
SOURCE: DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
SOURCE: Bernina Deco 340
You need to insert a blank USB into the Deco BEFORE loading any files on to it. Turn the Deco on and the Deco will create an EMB folder on the USB. Then you can add EXP files to the EMB folder and the Deco will read them.
SOURCE: Just got my used Bernina deco 650 from the shop. Tension off
pshawver is correct, I have 40 years experience working on sewing machines
