SOURCE: My Kawasaki Z 750 (2005) won't start. Starter
If the Tach is showing some RPMs then it must be turning the motor over, if the bike is just coming out of storage it may be gummed up in the fuel system. try turning the fuel petcock off and then on a couple of times. try to start the bike. Failing that, you may have to drain the fuel and replace it with new fuel.
if neither of these work you may have to consult a local mechanic for a spark test and fuel test.
SOURCE: need a kawasaki zxi 1100 owners manual
Most of the time you can look up the owners manual on websites as long as you can find the kawasaki website you should be good, i had the same problem with a dirt bitke and i found there website and found the owners manual and downloaded the owners manual and printed it out. Hope i was of some help to you.
SOURCE: 2001 sts 900 kawasaki jetski wont start
Check the engine compression with a compression tester. It should be over 100psi,also check for hot blue spark on plugs,if not blue ignition problem.Weak Spark,but if blue and wont fire with ether the rings maybe worn,and compression to low...Best of luck to you!!!!
SOURCE: my 1992 kawasaki zephyr 750 cut out and died when
sounds like your battery has an internal short circuit, time to change it and hope nothing else got damaged
SOURCE: 750 cranks but won't fire at all rode downtown
clean your carburetor and gas tank and change all sparkplugs
