The coffee maker is in a cabinet with a microwave beneath it.No apparent bolts or screws to remove. Please help
SOURCE: Removing over the range microwave
You can download the installation instructions, which are quite helpful when uninstalling.
We have uploaded them to our site for you here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
SOURCE: NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
SOURCE: need top cabinet template for ge spacesaver microwave-jvm1440whq2
You can download GE
owner's manuals and installation instructions here.
If it;s not there, you can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
