SOURCE: processor socket specs for acer aspire 8730-6095
Should be fine. Both are socket PGA478, but I would drop an email to Acer support to confirm.
SOURCE: f672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Testimonial: "my current processor is intel pentium dual core.i'll get a core 2 duo with 800mhz or less.thanks"
SOURCE: CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Testimonial: "WAIT A MINUTE I NEED ANOTHER REPLY!SO WHAT YOU'RE SAYING IS MY PENTIUM DUAL CORE CAN RUN GRID?"
SOURCE: how to overclock foxconn g41 mxe motherboard?i
ur overclocking depends on ur memory if u computer takes max mem, of 8 gig do 10 memory overclocking is much safer than over clocking mhz
SOURCE: how to overclock foxconn g41mxe motherboard with
I doubt very much you will get much response to overclocking here incase you do damage try www.overclockers.com
