SOURCE: Elna 9000 sews automatically
Most likely this is a problem in the foot control and it will need to be replaced or repaired.
sewman7
SOURCE: Elna 9000 presser foot
This is a cleaning issue. There is gummy residue holding your presser foot bar which needs to be cleaned out. Unfortunately, you need to split the case on your machine to access it for cleaning and this is best done by a qualified technician. Let's face it, it's probably been a long time since the machine was serviced anyway and they do work better with regular servicing.
sewman7
SOURCE: Elna Lotus pressure foot contoller and power cord
You can use a continental converter this has the normal 3 pin plug with a two pin connector on the front - B&Q stock them
SOURCE: i need to buy a
try visiting this website www.sewingpartsonline.com.au
this is a generic style snap on blind hem foot, you fold the fabric into a upside down Z shape and run the top folded edge along the white guide with the fabric under the foot, hard to explain but once youve done it once, it makes sense.
SOURCE: Why does foot petal lose pressure on Elna Air Electronic sewing machine?
Broken return spring.
Testimonial: "Where would that be found?"
