SOURCE: Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
SOURCE: nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
SOURCE: faulty nikon d40
I removed my lens and put it back on making sure that the aperture ring was set properly, that did it. The second time, I locked the aperture ring back in to its proper place and it worked fine.
SOURCE: how to delete pictures on INNOVAGE mini digital camera?
to clear the last photo, push MODE button till you see CL and hold the shutter button.
to clear all photos, push MODE button till you see CA and hold the shutter button.
go here for manual and drive; http://forums.cnet.com/5208-7593_102-0.html?messageID=2849222&tag=forums06;posts
SOURCE: Fuji FinePix F30 shutter problem: won't take pictures
Its fairly easily fixed and its a common problem with the F30. The
shutter button contact slides off upon impact when dropped, it must be
re-aligned so that it makes proper contact and performs normally. All
that is needed is the special screw driver for the F30 (easily
purchased online, just google it: "screw driver for fuji f30" ) or
bring it to your local watch/jewelry repair store and tell them to open
it up for you.
We have two F30's and they both have been
dropped, both did the same thing with the shutter button. But both were
easily fixed. Always keep the camera in a safe place and away from
kids, they are very sensitive devices. Use the wrist cord when taking
photos.
