Sewing Machines Logo
Grandma White Posted on Aug 20, 2017
Need to fix jam consew 105 cleaned hook still not workin
1helpful
I need help with my Consew 105. It doesn't have an oil pan under it so it needs to be oiled by hand. Where do I put the oil?
If the machine was supposed to have an oil pan, I would think you would not be able to successfully use it without one. It would be like trying to drive a car without an oil pan. You could try squirting oil into it every mile, but the machine would eventually quit because it requires a constant source of oil.
Try contacting the manufacturer:
Featured Machines
2answers
Need a manual for Consew 206RB. Any takers?
Servicing the Timing is NOT a home fix
I need to replace the cord and plug for a consew 105. Which wires go to what. New cord/plug has white black and green. The old plig had black and tan. Any help would be appreciated.
The new black will go to the old black, the new white will go to the old tan, the green will hook to the frame (case) or a screw there by the area where the new wires go into the case.
Consew 206 rb froze up suddenly-
You may want to lean the machine back and look very, very close for a very small piece of thread jammed in that race way. Resetting the timing is something you can do but first look for the simple stuff.
I recently moved and can't find the belt to my Consew 226. Having problems finding a replacement. Can you help!
Go to www.consew.com and download the parts list for the 224 Consew. It's the same as the 226 for parts. Or, go to www.diamondneedle.com. They have nearly every part you're likely to need. I got bobbin case screws, a hook, some metal reusable bobbins, and some needles, all at very reasonable prices.
2answers
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Bobbin thread
You may have bent the needle, replace that first.
Have you wound a new bobbin? Sometimes they wind poorly.
Check the hook race for thread "nests". (Bobbin casing)
Top Consew Sewing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
