SOURCE: ABOUT HOW MUCH IS TO UNLOCKED A 2 STROKE WAVE RUNNER 1200XL LIMITED
no idea on price but this sort of thing is used in salt water so although a new set of rings and a quick hone of the bore will sort it and maybe a new crank bearing as its obvious someone didnt put oil in with the petrol but the problem i have had with a lot of these fun machines is that getting the engine apart after salt water use is ?well lets just say difficult
SOURCE: Have hoover self propelled vac uh60010 new in box but out of warranty.
this video will show you the fix
Testimonial: "Thanks very much. Will check this out. Appreciate your video, very helpful, well done."
SOURCE: Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
