SOURCE: USIM message???
OMG!! ahahaha i worked out just after i posted. If you go to MESSAGING, SETTINGS, SERVICE MESSAGE, SERVICE MESSAGE, then turn MESSAGE RECEIVE to OFF this will stop the problem. Any issues, email me on [email protected].
Hope this helps :D
SOURCE: unable to send text messages
Generally if the phone is giving a "cannot send" or "message failed" error message then there is something wrong with the "switch" In order to fix this you need to contact your providers tech support and they should be able to fix the issue...
You can also try sending the picture to your own number... sometimes that will help push it through the switch...
Also make sure that you are using the area code of the numbers that you are sending it to...
Alltel for example, will not let the message go through if the area code is not inserted
SOURCE: phone not receiving/sending text messages
reset or format the phone..... backup ur data first...
SOURCE: will receive, but won't send text messages
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
SOURCE: Can't Send Messages
this yahoo messanger is turning out to be a big pain. have downloaded all versions and unistalled them in search of the solution for above mentioned problem..and still it doesnt work. wake up yahoo fellas...unless u have decided to wrap up ur messanger servies for good.
