Televison & Video Logo
A
Anonymous Posted on Aug 19, 2017
I have a TH-50PY700H TV linked to an M8S KitKat 4.4.2 Kodi TV Box but the top & bottom of the display is cut off. Can anyone help pls.
I have looked at TV manual & tried all the aspect settings but cannot fix the issue. I have read online that this might be an overscan issue but overscan, whilst shown as an option in the TV manual is not appearing on menu screen. TV box has HDMI connection & aspect ratio is set to 16:9 on TV. The input from Kodi box has been set at 720p not sure why & I can see the setting, but no option to change it.
electracon
Level 2:
Habit-Forming:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 118 Answers
  • Posted on Sep 07, 2017
electracon
Expert
Level 2:
Habit-Forming:
Night Owl:
Answers
118
Questions
0
Helped
25939
Points
211
If the signal is a product of the ott box than go to settings and find display. It will tell you how to make screen size to fit your screen.
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on May 26, 2008
SOURCE: My HDMI set top box
Make sure TV is set to HDMI channel.
Try a different HDMI port on back of TV.
Reset the cable/sat box and reset the TV by powering off both and unplugging them for the wall outlet for 30 seconds. Turn cable/sat box on first, and then TV after 30 secs.
If this fails, check the TV manufacturer's website to see if they have any software upgrades that will resolve the HDMI issue.
Anonymous
  • Posted on May 30, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Anonymous
  • 76 Answers
  • Posted on Dec 04, 2008
SOURCE: When connecting my Blue Ray
It all depends on the dvd that you are watching you cant change it to anything bigger than what is was recorded.
You will have to just watch it like it is. I have the same thing with my dvd player its really thin picture its annoying
Anonymous
  • 8619 Answers
  • Posted on Jul 22, 2009
SOURCE: LG LST-5100P set top box
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Bill Boyd
  • 53816 Answers
  • Posted on May 19, 2015
SOURCE: How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
I misplaced the power adapter for my mxq pro help
Android TV Box Power Supply Adapter 5V 2A AC/DC For M8S/M8S PRO/MXQ/MXQ PRO
5 VOLTS DC @ 2 AMPS... 95% sure it's a 3.5mm jack!
eBay:
Android TV Box Power Supply Adapter 5V 2A AC DC For M8S M8S PRO MXQ MXQ...
Cant get kodi to go to kodi screen
Keep hitting the back button on your remote. You will eventually get back to the main screen. Also to make things easier to use you should look into installing a kodi build. Check the link below for the top kodi builds to install on your android box. Theres also full tutorials with screenshots and youtube videos as well.
Best Kodi Build List for 2018 Must Read Before Installing BestBox
1helpful
2answers
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
M8S Tv Box their is no power off why
The remote that came with the box has a power on and off switch (upper left top of the remote and it would be red. After clicking on red button then you need to click the ok button and then you will get a power off with a rotating circle and then it should turn off. There is also an off button in some builds. Check out no limitsbuild (kodi nolimits build on youtube channel
How come the top and sometimes the bottom of my screen are cut off
Not all bradcast are in 16:9 resolution (wide screen). Most are still in 4:3 (old TV).
Sometime the advertisements are in 16:9 letterbox to project correctly on 4:3 TV and TV logo or titles are on the bottom or top of the picture. If TV is set to project wide screen, these logos or writings will be cut off.
If you have an option to switch TV resolution from remount, you will see whole picture.
Check your TV manual for settings.
Top TV Box Televison & Video Experts
ADMIN Eric
ADMIN Eric
Larry
john h
Are you a TV Box Televison and Video Expert? Answer questions, earn points and help others
