Notes:
1. When replacing the NVRAM or the EEPROM board, if the parts are replaced with used parts, the License Management error condition cannot be resolved by performing the repair operation.
In this scenario, Initialization would then be necessary and support must be contacted.
Additionally, if both the NVRAM and the EEPROM board are replaced, Initialization will be necessary.
IMPORTANT: Perform the Repair Procedure first, then the Initialize procedure. If initialization is required, collect the following information before calling support:
2. Make sure to enter the MFP Serial Number, Repair Demand Code and the Request Code in uppercase letters when entering data in License Management Server online.
3. Version 88 firmware refers to the bizhub C353 and bizhub C650 series models. Other models have the correct firmware from factory.
4. To view a PDF, you may need to download a free copy of Adobe Reader®.
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: Printing consecutive page numbers on multiple documents
look in applications (mainscreen) and I thinkit's under stamps/overlays. You might even be able to choose what page number to start with
SOURCE: Hi i have A problem with Konica C650 , error
if the waste toner box was recently replaced either it is defective or the waste box sensors need to cleaned or replaced the sensors are located on the front door on this machine if you have some canned air blow them out and or replace the waste toner box
