SOURCE: The hand held dyson does not appear to charge.
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear. This can be quite hard work, and you may find a bit of additional leverage from a flat-blade screwdriver is helpful. It's a bit more difficult to answer your question about buying a new battery. The fact that the red light comes on would suggest that your charger is working, so the finger of suspicion does point to the battery, but without testing equipment it's impossible to be sure.
SOURCE: my dyson dc 16 hand held vacume stops & starts
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
SOURCE: I have a dyson hand held that shuts off after just
yeap..... i just found a fix for this ,, its mad how easy it is to fix as well...and it works 100%,,,
now dyson implemented a filter magnetic switch if u take your filter off you will see a small magnet in the corner,, u will notice where the magnet is behind it is rased platic,, now,,that the problem on the main board the transistor that picks up magentic signal from the filter is dud,!
dont ask me why it happens,, its a pain i know.,.
now take off collection pot for dust now take battery off.
now where the serial number is theres 2 hex screws that need taking out..
now u will see a small pcb board.. remove with one tiny security screw holding it in,, once removed pull both red plug off thats the digital motor plug.. and white plug which is vcc..to battery,, once u have done this pull the board down and back gently. as there is a long bit of board that goes up the back of the dyson plastic be very carefull pull this out.. now the long and thin pcb board that is hidden is what we need there is a tiny transistor,,, we need to remove this carefully..once removed,, we solder a thin wire from 2 point A+C need to be soldered together with a thin piece of wire, it will not harm the motor.. as long as u keep it clean,,
these points corolate to the transistor,,
A
B C
SOLDER AND A+C WITH A FINE PIECE OF WIRE NOW,, AND WALLAH... fixed put it all back together again,,, charge the battery,, and your away,,, working again,, if not u have other faults.. but 99% fix this with flashing red led,,,!!
SOURCE: Hi my dyson hand held
take it apart and look for some trash might be rapped around the motor,because if the motor heats up it will shut down to keep it from burning up
SOURCE: I have a hand held Dyson model dc16 and it does
I'm sorry to hear you're having difficulties with your DC16. If you'd like to purchase a replacement battery, you can do so via our online store - visit www.dyson.com and click 'Spares'.
Alternatively, if you'd like to order over the phone, or if you'd prefer to consult one of our experts before making a purchase, please call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
try running it without the filter first,see if it still has the same fault. sounds like the machine is shutting off automatically because its overheating the motor.
