Lands Phones Logo
S
Selwyn Skinner Posted on Aug 15, 2017
To set up my panasonic KX-TG633 cordlessphone
1helpful
I've a Panasonic single set cordless KX-TG3711BX. I wanted to add a second handset to this system. So I've two questions: one, is the cordless able to handle a second handset at all? And if so, what model...
According to the specifications sheet, you can add the KX-TGA371 handset to the KX-TG3711BX cordless system. The handset comes in black or platinum silver. The specification sheet is available here: http://www.mcadvance.com/pdf/kxtg3711-12-21-22bx.pdf . ManualsLib has the manual for the KX-TG3711BX here: https://www.manualslib.com/manual/1137517/Panasonic-Kx-Tg3711bx.html .
However, I only found one site listing the KX-TGA371BX handset. The site, https://www.pabxlao.com/products/cordlessphone/kx-tga371bx-detail , did not have an obvious option for ordering the handset.
I hope this helps.
Turn ringer on for panasonic KX-TGA273S cordless phone
The handset for the Panasonic KX-TGA273S needs to be paired with a compatible Panasonic cordless phone system like the KX-TG2700. You can turn on the handset ringer by pressing Conf/Function on the handset (lower left) when it is in standby mode. Scroll through the list to Ringer setting with the appropriate arrow keys. Press the right arrow key and scroll to Ringer volume. Press the right arrow. Then press the up arrow and press the soft key for save. This sets the ringer to low. Use the up/down arrows to set the volume. Note: pressing down repeatedly sets the ringer volume to Off. Press Save and End to exit the menu.
The manual for the KX-TGA273S is available on the product page: http://shop.panasonic.com/support-only/KX-TGA273S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga273s_mul_om.pdf . The manual for the KX-TG2700 is available at ManualsLib: https://www.manualslib.com/manual/303875/Panasonic-Kx-Tg2700.html . See page 19, https://www.manualslib.com/manual/303875/Panasonic-Kx-Tg2700.html?page=19#manual .
I hope this helps.
Manuel for Panasonic phone KX-TG8521E/8522
Hi Mrs D, The link below is a Free 60 page operating instruction manual for a panasonic phone Model No. KX-TG8521E / KX-TG8522E / KX-TG8523E / KX-TG8524E, Take care....... CHEERS..
http://download.pfrnco.com/product/catalog/cordlessphone/KX-TG8521.pdf
1helpful
Speaker failure on Panasonic cordless
I had the same problem with my last Panasonic cordless set. I fixed them with some very small speakers from ear buds but for the price of cordlessphones these days just get new ones.
I can't make outgoing calls on my Panasonic KX-TG8521E. Recieving incoming calls. When I dial a number, all I hear is the dial tone. The handset is not locked
You need to press the Phone or Speaker button or the soft key for Phone (see the LCD screen) after entering the phone number to dial the phone. Until you do, you can edit the phone number without actually making the call.
The manual for the KX-TG8521 is available here: http://download.pfrnco.com/product/catalog/cordlessphone/KX-TG8521.pdf . See page 16 for the section on making a call.
I hope this helps.
Users guide for panasonic cordless hand set kx
users guide for panasonic cordless hand set kx t4027 do not know how to program in new numbers need users guide
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
