SOURCE: Remote
Hello creyn,
why dont you join both TV n Theater system remotes togather with rubber band?
SOURCE: Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
SOURCE: remote control codes for a Bose Cinemate
I would contact ur nearest Bose dealer or Contact the company through the website to get a replacement remote, you will of course need the serial number for the product when you contact them, using a universal remote can make things easier but you will not be able to access most of the functions without the original
SOURCE: Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
