GE 74801 Clock Radio Logo
A
Anonymous Posted on Aug 12, 2017
GE super slim 7-5295 kitchen cd/radio was unhooked stored in box for year took out plugged in and only under mount light worked everything else nothing happened. Opened and no loose or disconnected wires not dropped etc
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 30, 2007
SOURCE: Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • Posted on Apr 23, 2008
SOURCE: I am on my third dispenser light bulb Unit is less then two years old.OEM bulbs are not available from local GE stores and bulbs from Big Box stores will not work.What can do? Service Call is $69.00
From Button Box,
adid not have time to work on the light problem,will need some time,but will give it a try.Thanks for the info.
BB
Anonymous
  • 109 Answers
  • Posted on Nov 19, 2008
SOURCE: Ignition key turns on but car will not start
I suspect the ignition switch is malfunctioning.
Anonymous
  • Posted on Jan 15, 2009
SOURCE: radio/cd will not work,or even light up..2006 PT Cruiser
Hi, Check fuses, check the ground.
Anonymous
  • Posted on Feb 07, 2009
SOURCE: radio does not turn on
listening to the radio, just stopped working no power with cord
I need instructions on how to set the clock and use the cd and radio on the ge spacemaker 75292a/super slim kitchen cd
These GE Spacemaker Superslim Kitchen CD Players can't be found even on the GE Appliances site. Even a Google site search of GE Appliances turns up nothing for 7-5292a. I can find some pictures of the line of these devices on ebay but that's about all. However, you do have two options at least. You can contact GE support. --Or, you can take a look at this manual I found for the 7-5330 model and see if its instructions help you. I have not found a manual for your model on the web. Page 6 of the manual below offers instructions to setting a clock, page 7 for radio, page 8 for CD.
GE Spacemaker 7 5330 User Manual
http://www.geappliances.com/ge/service-and-support/contact.htm?icid=GEARtopnav-contact
Fuse box location for 94 ford club wagon
Under dash on left driver side,another under hood mounted on driver fender,some were put in the glove box. Most are under the driver's side dash and a small auxiliary one under the hood with a few relays. Chassis sent to conversion companies sometimes get shifted to the glove box or god forbid other locations.
Numark CD DJ IN A BOX w/2-NDX200s/M1a/HEADPHN - NUCDDJINABOX ONE OF THE CD WONT EJECT
Was it working at first, and it just stopped? Try unhooking everything and just isolate the one cdj and plug it in see if it will eject. If its Brand New and this just started happening my sugguestion is to take it back to the store. you get what you pay for and numarks whole dj in a box line is the bottom line stuff.
This Fisher slim 1500 has never been used. I can't turn it on or make the cd work. I can't even turn on the news in the morning. I installed batteries, hung it on a wall and now it won't work at all. I...
For Fisher SLIM 1500SL model, I figured it out as below.
1/-Plug into AC & you will see Standby ON with AM 12:00.
2/-Press Timer button & you will see TIMER at left top corner.
3/-Press and hold Standby button until entire screen is ON & Standby goes OFF. Everything will go from here- play CD, radio, etc.
Goodluck.
1helpful
I'm trying to find a User Manual for a GE Spacemaker 7 5295
Right after I posted my request, I managed to find a suitable Users Manual on the web. Thanks for your help.
Replaced bake element but range won't turn on
Not a happy circumstance.
An old message and you have probably found the problem by now; if you have, you might post it back here as a comment to aid others.
There may be  fuse mounted inside the back panel of the upright. Unplug the range before removing anything that may expose lethal voltages.
Happy New Year
4helpful
3answers
Whirlpool Super Capacity 465
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tries turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
5helpful
GE Slim Spacemaker 7-5295 CD
Make your own template with some thin cardboard. (cereal box) Turn the unit upside-down with the 3 spacers in place & mark their location with a pencil. Then mark the front edge & sides of the radio onto the cardboard. Instant template!
No power
My guess is that when you pushed the player into the dash, you pinched a power wire, resulting in a blown fuse. Check the vehicle's fuse box. Most vehicles have at least two fuses that provide power to the radio, though they may not all be labeled as radio fuses. You may need to check all the fuses in the vehicle, including any fuse box under the hood.
Top GE Audio Players & Recorders Experts
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
