Question about IT Works Cameras
My K30 suddenly started taking all dark photos yesterday. I was shooting an event a work, everything was going fine, I went to break..came back.. and nothing on the screen.
The only thing I get on the screen is the extreme highlights in a scene. I've made sure the LCD isn't broken.. other than image playback it works fine. When I put the card in a computer the images I reference now are dark too, just as displayed in camera. I've reset the camera to factory default, tried 3 different (including one manual lens) and still nothing. Oddly though, when using the manual lens (a really old 50mm) I get more display but then the camera..after I take a photo..takes more photos or seems to, on it's own. Either it's taking photos or the mirror is flipping up on it's own. Please help.. can't afford a new camera right now
  • IT Works Master
  • 6,140 Answers
Look on the Pentax Forums for K30 aperture block
Posted on Aug 11, 2017
6ya staff
SOURCE:
Ron Bower
  • 130 Answers
SOURCE: No Image on display screen
Does the play back show any of the pictures you have taken before? are you sure the little lens cover is opening? there is a shield that closes down to keep the lens protected from debris and finger prints. Sometimes they can get jammed and not open. Tap on the front of the lens see if it opens. Switch it to auto mode if its not in auto mode.
Posted on Apr 05, 2006
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: lcd screen does not display viewfinder image
That is normal. Didital SLRs are different in this respect from digital compacts .
Posted on Sep 02, 2007
t00nz
CameraR
  • 4738 Answers
SOURCE: Canon A85 - Can't take Pics
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 03, 2008
Anonymous
SOURCE: LCD screen shows weird colours
YEAH GO TO WWW.BUY202.COM HE HAS LCDS CHEAP
Posted on Sep 06, 2008
Anonymous
SOURCE: error messages "cannot display image" or memory card error, etc.
Try a different SD card to start.
Posted on Dec 26, 2008
Frigidaire refrigerator model frs28zgeb
Check your plug-in connection at your outlet. Most likely source of power loss. Beyond that, you need a wiring diagram to trouble shoot this issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 16, 2017 | Refrigerators
This is an edit of my original problem posted a few minutes ago. I'm replacing a foyer light that is operated by a double light switch ON THE WALL (switch 1 turns on the foyer light, switch 2 turns on...
Wiring is difficult to see without clear description of each wire inside the box... and more difficult when folks take wiring apart without taking photo of wiring before starting. Then they throw away the old switch,,, so comparison cannot be made to new switch.
That being said:
Did you install a new 3-way switch?
Is it a 3-way switch with 2 brass screws and 1 dark screw and 1 green screw? The dark-colored screw is common screw.
If you installed new 3-way switch, then it is probably wired wrong.
Or there is damage to a wire that is not covered with repair... or both bad wire and wrong wiring.
Look at OLD 3-way switch and identify which screw is the common screw. Should be marked on back of device.
Identify which wire went to common screw on OLD switch.
Look at NEW switch, and identify which is the common screw (dark-colored screw), and then attach OLD common wire to NEW common screw.
Otherwise, put old switch back into box... see if it works... take some photos... attach photos to comment to this thread ... take photo of new switch from back, showing all screws so I can see what is going on.
We can fix it it...and I will be here all evening to assist.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 19, 2013 | Home
My Nikon CoolPix S560 has worked great since I bought it about 2 1/2 yrs ago. I know how to set everything, the battery is fine and charged. Natural light photos are fine. Just recently in the middle of an...
Yes, the flash can burn out or the flash circuit can short out. You can send it in for service but, since it's out of warranty, it will be very expensive. B&H photo has a refurbished one for $70. If you send yours in, what you will get back is a refurbished one....they do not bother to fix point-and -shoot cameras. Your choice.
Jun 13, 2011 | Nikon Coolpix S560 Digital Camera
My Canon EOS rebel suddenly won't take pictures in dim light. The flash pops up and blinks and blinks trying to register the image but won't ever autofocus and take the picture. The light has to be very...
To autofocus the sensor needs a fair amount of contrast (light and dark eges) to operate. If you're trying to take a photo in a dim room of a dark colored subject for instance the focus won't lock and the camera won't take the picture. Try switching your lens to manual focus and shoot that way.
Jan 07, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
My 70-200 is acting up. When mounted and shooting,
yes- the internal mechanicsw of hte lens pull from the camera body - are the contacts between the lens and body clean? your probably going to need to send the lens in for repair. :(
Mar 07, 2017 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
The car ran fine yesterday. i changed the valve cover gasket and fuel filter, then to take off intake manifold, i had to take off the fuel rails. everything went back together fine, but when it was time to...
First thing I'd do is check if everything was connected, vacuum lines, fuel lines, connectors, etc. If all good, check the fuses and fuel pump relay. My guess would be the vac line to the fuel pressure regulator.
Nov 22, 2009 | Mazda MX-3 Cars & Trucks
Kodak c340..water in lens...
i kept the camera on, that means the lens was open too..........after a good 4-5hours later when i checked it was back to ''foggy'', and another few hours later it was back to normal.........hurrah!!
Feb 02, 2009 | Kodak EasyShare One Digital Camera
LED display on powershot a630 is very dark. It was working fine, and then when I moved the display it suddenly went dark
pershaps that the cable inside to power the lcd is defect. or it could also be that the backlight is defect . those things can be repaired (don't do it your self) but costs could well be higher than buying a new camera
Mar 22, 2008 | Canon PowerShot A520 Digital Camera
Intermittent problem
sometimes, by changing the swithces of the control panel solves the problem
Oct 13, 2006 | Sony Cyber-Shot DSC-S85 Digital Camera
Cameras Logo
57 people viewed this question
Top IT Works Cameras Experts
Bill Boyd
Tony Parsons
Tony Parsons
Huseyin Huseyin
Huseyin Huseyin
Are you an IT Works Camera Expert? Answer questions, earn points and help others
