SOURCE: which file formats are supported
mpeg 2 is avi does mp3s reads alot samsung has one of best readers i seen best bet is mpeg2 tho 720x480 29.97 fps wide ok
SOURCE: LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
SOURCE: hd movie format supportet with samsung home theater
well, i think mpeg4 is the format u need. this format can be accepted by hd home theater. And u should use this video tool which can convert any video files to mp4. Besides, it can offer u mp4 hd format as output format. Then u will not worry about quality loss.
Have a try:
http://www.pavtube.com/video_converter/
SOURCE: hi i have
you can't and DIVX is an AVI format. MKV is an entirely different encoding format. There are no TVs or DVD players that support MKV. Also you will not get a DVD player that will paly BlueRay. DVD and BluRay require 2 different lasers on the drive to read the format so your software will not allow for this through a USB or hdmi either. You have what you have and there is nothing you can do aside from using the PC the movies were pirated from and connect it to the TV.
