SOURCE: Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
SOURCE: I need to change a cooker lightbulb
You should just be able to pull the cover off tords you if it is flush to the serface or you might have to unscrew it. Try thouse things first.
SOURCE: Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
SOURCE: In 1991 I bought in
This might be a hard exact item to replace, but look at the old capacitor and write down any information on it- uF capacity should be written on the old capacitor. These are metal body, electrolytic caps, and so an equivalent cap, rated the same, will work, although not be an exact fit, so you will have to jury rig it (improvise).
Here are typical specs on a cap:
http://www.capacitorindustries.com/capacitors/microwave-capacitors/sph85/default.html
Here are some caps on Ebay, and a lot of shippers are international. Here is the page:
http://shop.ebay.com/i.html?_nkw=microwave+capacitor
If you cannot find what you're looking for on Ebay, contact the following vendor:
http://www.rell.com/content/english/aboutus/Pages/Supplier.aspx
If you explain your dilemma, they might be able to suggest a replacement part.
Good luck, hope this helps, and thanks for using FixYa.
SOURCE: I have a Siemens Microwelle
Please check your Enr number..
1st link for spares, 2nd link to download manual
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/indexs.htm
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
