SOURCE: conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit
will shut down until the power is restored. One 9-volt battery must be
installed to retain your personal greeting message and incoming
messages during the power failure. Occasionally outside factors, such
as power surges, may adversely affect the unit. If the unit is not
operating properly or if the light continues to flash once power is
restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
SOURCE: Remote retrieval of messages
Call your phone number. After the greeting is finished and you hear the beep to leave a message push 123 on a touch tone phone and you will be given a list of things you can choose to do including listening to messages. 123 is the default security code unless the security code has been changed. Since you dont know how to retrieve messages Im assuming the default security code has never been changed.
If 123 is not the default security code and you dont know what the code is, you can change your code in the setup menu. You get to this by pushing the stop/set button on the answering machine and holding it for a couple of seconds. Since GE doesnt offer a downloadable manual for the 29878GE1 you should probably take a look at the manual for the 29875GE1 which is basically the same model with the addition of a digital message counter. Hope this helps.
SOURCE: System keeps flashing with CL
Program the clock. There are a some buttons on the back of the base unit that sets day of the week, hour, and minute.
SOURCE: Audiovox Digital Answering System Operating Steps
i found this after searching the web for a long, long time.
http://safemanuals.com/user-guide-instructions-owner-manual/AUDIOVOX/AXT847-_E
SOURCE: Digital Answering machine GE #29875GE1-B
Call your phone number where you have the answering machine connected.
After you here the beep that follows your greeting or during your greeting before the beep enter your security code. It is factory set at 123.
It will recognize your code and begin playing the remote function.
Follow the instructions from there to hear your messages.
