SOURCE: I purchased a LG Dehumidifier
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
SOURCE: LG Dehumidifier overflows when attachment tube/hose attached
SOURCE: Water from LG 30 pt dehumidifier drains into
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
SOURCE: LG dehumidifier won't drain through hose anymore.
Make sure hose is flat with no high or low spots. Blow or **** out hose and pour somr bleach water through hose.
SOURCE: DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
