Either you do not have sufficient toner remaining or your toner sensor is falsely saying such. Follow your procedure for installing toner. If memory serves me, some toner cartridges have to be shaken but don't rely on my memory, follow the instructions.
If toner replacement does not fix the error, try resetting the machine. If that does not clear the problem, you may have to call tech support for a service call.
SOURCE: develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
SOURCE: DEVELOP INEO 5501 PRINTER PROBLEM CALL
you better browse the below site,
www.develop.de/en/news_archive/0__news-archiv.htmThe problem is that, up to now, the cost of printing or copying monochrome .... A new colour printer launched by DEVELOP, the ineo+ 31P, is specifically designed for ... finishing functions - all characteristics of the new ineo+ 5501. ...
ineo Remote Care - Developwww.develop.de/en/products/.../65__produkte-detail.htmineo Remote Care: Maximum support, maximum benefit - via remote diagnosis ...
SOURCE: I have a Develop
C0F32: Faulty ATDC Sensor Gently swing the IU in the horizontal direction to even out developer Change ATDC Sensor (UN1) and Change Master Board (copier:
in the Developer Mixing Chamber.
Clean ATDC Sensor (UN1).
developer.
PWB-A).
SOURCE: Develop ineo 250 Error C2557 How reset it?
Just reset the pc life and run F8, code 2557 will reset. You will reset the pc life while the right door is open or else anoying buzzer will come everytime you turn ON the sw. I hope you know the right procedures on resetting pc counters. Then add little toner on developer and run F8. Some tricks you have to do in here.... Little dark copies are expected but after a week or two the copies will surely great!
Dear friends,
I too have the same problem, my service printer has the code: c-2214.
I tried with all the methods offered by the manual service, but no success.
can you help me find a solution to this problem?
Michee Kikasa
