Question about Canon Computers & Internet
THERE IS DOCUMENT JAM ON DOCUMENT FEEDER WHILE THERE IS NO DOCUMENT FEEDER CANON IR 2016J
THE RAM HAVE BEEN PLUGGED OUT AND INSERTED AGAIN BUT WITH NO SUCCES
    Habit-Forming:
  • 95 Answers
Remove the motherboard and try it again.
Posted on Feb 04, 2019
Anonymous
SOURCE:
uvagt
SOURCE: Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Posted on Mar 09, 2008
Anonymous
SOURCE: paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Posted on Feb 20, 2009
Anonymous
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
Anonymous
  • 39 Answers
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
Posted on Dec 18, 2009
Anonymous
SOURCE: automatic document feeder pulls paper through only part way
You need to replace the document feeder motor the gears on the motor shaft are split and slipping. New motor is 12.72 at http://www.compassmicro.com/parts2.cfm
Posted on Jul 13, 2010
Canon ir 2016j out of toner change of toner
Hello Asim.
Are you asking what toner replacement cartridge to use?
Your toner should have a sticker with this number on it.
Otherwise Google
canon ir 2016j toner renewal
The above search may also show results for how to replace.
Nov 18, 2017 | Canon Office Equipment & Supplies
How do i fix Error E007 on Canon IR 2016j?
Dear
Replace the fixing film assembly or fixing film.
Thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Canon ir 2016j display scanning without printing
frist remove the Ram & then reinstall it if the problem presist then cross check the i.p board
Jan 03, 2013 | Canon iR 2016i Black and White Copier
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
What does document in ADF mean
Hello, Thanks for using Fixya today.
ADF is auto document feeder, used to feed a document into a scanner or printer. The error is associated when there is a document or paper jam at the document feeder, or paper trail.
This would happen mostly on scanners and all in one printers after witch a document is left in the feeder or there was a paper jam occurrence. We hope this answers your questions today?
Please contact us again if you still have a issue, or need help with anything else.
Thanks for using Fixya.com
Best regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
I am Guna from malaysia, iam having problem with canon ir 2016j copier. Its always paper jam at bypass feeder. so i notice that the bypass tray guide broken.so i need to order the parts. i dont have parts...
salut
d'abord je tien a vous dire que je suis un technichien par vraiment bien qualifie dans le domaine
des photocopieur mais j'ai une petite experience dans ce sens ainsi je suis de l'algerie alore je pouvais me contacte sur cette adresse fahimriad@yahoo.fr
riad of algeria 0773 70 28 71
Feb 23, 2009 | Canon iR 2016i Black and White Copier
Computers & Internet Logo
Top Canon Computers & Internet Experts
old marine
old marine
Davit Mamyan
Davit Mamyan
robert roberts
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
