Will not complete cycle and delicate light keeps flashing.
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
SOURCE: fast and delicate flashing
Your control panel is bad.My advice is use your warranty if you have it .If you don't ,toss this machine out,there should have been a re-call on this .You are one of many many that are having to deal with a problem that the manufacturer should be liable for. Dont't let GE (hotpoint) go not knowing that your D/W is broken ,look for a class action law suit to be in the making,which is not enough to correct the problems at hand .I don't advise repairing this unless there is a modified part to replace the defective one. Again I'm with you on this ,and sorry for all the consumers that are ripped off by manufacturers (in my eyes) . Please rate this !
It says in the manual to check the heating element.
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
