Ex. I can use smart app, go to Netflix, movie selection is normal. Select movie, get grey snow, audio and subtitles ok.
SOURCE: lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use.
To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing.
Let's start with the recording.
Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording.
Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out.
Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.
Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded.
YELLOW is always video.
SOURCE: Hi, how to enable subtitles for
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
SOURCE: brand new dmr-ez49veb,has worked ok on setting it
i have a panasonic dvd rcorder / video combi model DMR-EZ49VEB. I have recorded something on DVD, which is 4 hours in duration, and I want to edit the recording and split it into parts. I follow the manual, but when I press EDIT the option to split isnt even there? I am confused, it is SUCH a difficult manual to deciphre, but the only 2 options there are "Edit title name" and "Change Thumbnail". The others are not listed. the disc is not copy protected or locked and is of sufficient duration to split the contents. HELP PLEASE :(
solved.
1- turn off you router
2-go to settings
3-ok on the ? (support)
4-inatialisation of premium.
Problem solved
