SOURCE: sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
SOURCE: dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
SOURCE: housing melted around lamp
Please call a sony authorized service center . Sony I believe is still extending warranty on this model for this problem.
SOURCE: replace bulb sony KF-60XBR800
When you are in front of tv grasp the right side of the front grill and pull it off, the lamp door is right behind it. Unscrew the cover and remove it, you will need the allen wrench provided with the new lamp to remove the old lamp just unscrew it and pull it out.
SOURCE: Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
