Need the carburator and linkage info . It wont sray running , even after gaskets replacement.
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
SOURCE: coleman 5000 generater-no AC output
Pull off the cover at the end of the generator and locate a 2 lead capacitor, it should read 130UF 200V and replace it, they often go bad and you will not have any output if they are. colman has them for 20.00 shipped. 1-800-445-1805
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
SOURCE: yardman 173cc wont stay running as long as you
the jet in the carb sounds like it is clogged
