Toshiba Satellite A215-S7462 Laptop Logo
Posted on Jul 27, 2009
I need to change the motherboard for a Toshiba Satellite A215-s6816 but I don't find anywhere the repair manual for it. Do you know where I can get it? Thanks!
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 27, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1133
Points
17
Try this website it helped me a lot http://www.irisvista.com/tech/
2answers
Diagrams for Toshiba A215 S7437
The Toshiba Satellite A215-S7437 Notebook PC, is one of the Satellite A215 series of Notebook PC's. It is a fancier version of the A200 series.
Pictorial guide to disassembly of the A200/A205 series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
[Note* Page 2, 3, and 4, are listed at the top, and bottom of the page.
In white; Page1::Page2::Page3::Page4::Find another model ]
Service Manual for the Toshiba Satellite A215 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the main heading - Toshiba, go down to the subheading -
Satellite A10. (A10 in blue)
Go across, and click on A215. (In blue)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { A215 }, it may take up to 30 seconds before the first page comes up.
The motherboard diagram follows this diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The CPU is an AMD Athlon 64 X2 TL-58, (Turion Core ), mobile Processor,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29_2
Processor has two processor cores that can operate up to 1900MegaHertz, or also stated as 1.9GigaHertz.
(1900MHz/1.9GHz)
Does Not mean a total of 3.8GHz.
Total is still 1.9GHz. It's just two processor cores teaming up on the same task.
Chip and Chipset denote I.C.
Integrated Circuit.
The motherboard chipset is an ATI RX-690 (Southbridge chip is ATI SB600 )
http://en.wikipedia.org/wiki/AMD_690_chipset_series
For additional questions please post in a Comment.
Regards,
joecoolvette
My satellite A215-S6816 can't detect surround 5.1.. i use vista x32 official from the notebook.. what driver i must install or any hardware can solve my problem without open my comp, because i don't...
If you were to browse toshiba.com and look up your model it will guide you to the upgraded drivers and BIOS firmware.
I feel sure that there will be your answer.
My toshiba laptop is askingn for a password to turn on. I know this relates to the cmos battery. I have the toshiba satellite A215-S7413, how to i get to the cmos battery?
How to get to the CMOS battery
The Toshiba Satellite A215-S4747 Notebook PC's CMOS battery, is soldered to a bracket on the bottom of the motherboard.
The laptop has to be completely disassembled to access it.
In this photo showing the bottom of the motherboard, the CMOS battery is in the middle,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-21.jpg
This is a link to a free Service Manual, detailing disassembly,
Go to the 11th line down. The one that starts with Satellite A10
Go across and click on A215
This is a PDF file. It may take up to 30 seconds before you see the first page, and additional time to fully download.
Suggest you let the file download all the way before looking through it.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
Suggest you bu and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
Average price is around $3 to $6.
3) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
There may be as many as 60 screws and 12 different types.
Do Not mix them up.
(You can use a clean egg carton in a pinch. Mark each egg holder)
I have a Toshiba Satellite A215-S6816 series laptop. I fell asleep watching a DVD one night - when I woke up the next morning everything was dead. I took it to a store where they said that all power...
Please confirm if the laptop was running with or without the battery adapter when you were playing the DVD.
Take the battery out from the laptop and start with the battery adapter connected and see if you see any activity.
Laptops don't die like that.
My Toshiba Satellite a215 s7422 wouldn't boot
i don't believe you would get that far if it was the motherboard.
I cant bypass the bios password
i would phone up the toshiba helpline on : 0870 843 0333
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
2answers
Unable to play DVDs
Please insert single layer DVD. they will be detected.
The DVD Player in ur pc can not read double/dual layer DVD's.
My laptop would not connect to wireless while I was away in a hotel
Open up you're network connections in you're notebook & run the wireless wizard. Search for you're home wireless network.
You should be able to connect to you're home. Remove any other networks you might find. While you're at it I suggest you setup security for you're home network with a password.
Let me know how it goes.
Mike
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
