Make sure the feed dogs are not in the dropped position (for darning).
If it is very light-weight fabric, most machines will have a presser foot pressure adjustment that will increase the presser foot's pressure on the feed dogs, thus pulling the fabric through better.
Make sure the feed dogs are clean--no debris stuck between the teeth, under the feed dogs, or around the bobbin case. If it is an older machine that has been used a lot, the feed dogs could be worn down and need replacement or adjustment. (Do not run the machine with the presser foot directly on the feed dogs. This will cause excessive wear to the feed dogs and the presser foot.)
