You'll need to verify you have spark. Could be ignition module fails at operating temperature. Let unit cool for a couple hours. If it starts and runs for few minutes then dies, check spark... no spark then failing ignition module.
If spark checks out ok then likely carburetor or crankcase leak. Carbs are inexpensive, replace. If still same problem then test for crankcase leak (search WWW for how to).
SOURCE: started stalling after last usage. then it would not start
When cleaning the carburetor make sure the small screen is free of debris.
(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),
to clean the small portals in carb. These portals can
become blocked and will keep the mower from running. Reassemble and start. Good luck!!
If you need further assistance, just let me know.
Jim
SOURCE: Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
Good luck...
One more...
SOURCE: Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
