Breitling Aerospace 455 Wrist Watch Logo
Posted on Jul 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
B-1 brietling the problem is ,,, you need to rotate the knob to much to change the functions
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Jul 27, 2009
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
34513
Points
119
Well if the watch is performing its functions properly then there's nothing wrong with it technically. The only way one could make it require less turns would be to custom make the necessary parts with different ratios and unless you have got lots of money to spend on that .......
Breitling airwulf second hand not moving all other functions working ok how do I fix this
Send to brietling or a competent watch repairer who is able to get spares as brietling are a bit tight with spare parts
1helpful
How to change the date in edifice EF - 550
To change the date on the Edifice Casio wristwatch pull out the knob to set time only half way - not fully otherwise you can change the time only. Then rotate the knob ANTI clockwise until you reach the desired date and push back the knob fully to return to normal
1helpful
How to set the watch?
Gently pull on the "knob" on the side of the watch. You may have to get your fingernails between the watch edge and the knob. It will pull out a little bit, then a little more. One position will change the time. The other position will change the date (if it has a date function) If it has multiple knobs/buttons, it is typically the one on the right side that doesn't have smooth edges.
Hands will not move
Who installed the battery, are they competent?
If they are take it back to them for repair in not send it to Brietling service for repair.
This is not a DIY job.
2answers
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 • Watches
Breitling has a weird noise when shaken (sounds mechanical) and seconds hand wont work (usually it does if you move watch)
Sounds pretty serious!
The most likely thing to go wrong is the balance wheel has become dislodged. The most likely cause of this is being dropped onto ahard surface.
It needs to go to a Brietling dealer for repair.
How do you adjust the time on a bentley Brietling watch
You can get advice from one of their service centers which you can locate by going to their web site- http://www.breitling.com/en/index.php#/home/. On the lower left if a small menu, choose "service centers" and fill in the required details.
May 07, 2010 • Watches
1helpful
I want to remove the front glass of my watch
You can do it only after the movement is taken out. And for glass removal you need a special press. Save your nerves and your watch - visit your nearest watch maker and ask him to do that.
How to change day on Arkitekt FS-4252
just pull the round knob once(very lightly pull it out) and keep rotating for few seconds and the date will change.
Top Breitling Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Breitling Watch Expert? Answer questions, earn points and help others
