I set my dvr to my own personal settings and saved them. we recently had a power outtage and my dvr went through an irregular shut down and reboot well now its telling me my password is incorrect and my user nameis incorrect i know its not so i continued to try it until the dvr completely locked me out now i just want to smash it in to a million pieces but i need it soim tryingthe option ofcontacting you for a little assistance to get it factory reset so i can have access to it once more. please help me so idont destroy my security device. thank you
SOURCE: Sim Lock
did u try this one * 2 7 6 7 * 3 8 5 5 # it removes simlock but with all the pictures n music u had on the cell along with phonebook contacts saved on the phone
SOURCE: user password lockout - Vissta home premium
you can search for a password boot disk which will disable the administrator password.
There are dozens of these types of programs but one program I recommend is windows password reset 6.0
http://www.resetwindowspassword.com
Download the iso file and burn it to a disk to create the boot disk,
that simple. Configure your pc or laptop to boot in the cd drive,
insert the CD and it would boot then just disable the password and
restart.
Took about 5 minutes for the whole process.
SOURCE: LINKSYS SPA-2102 CAN NOT FACTORY RESET, PASSWORD REQUIRED!!
You need to:
1) figure out where it's going for config file updates (e.g. http://ip address/path/filename (wireshark highly recommended for this)
2) once you have the filename, you need to find a "broken" copy of that CFG file. You may be able to use the broken sunrocket one (google linksys2102-sunrocket.cfg)
3) setup a webserver to it appears to be at the ip address above (there are a number of ways to do this - google sunrocket 2102 for some step-by-step instructions.
4) reboot the SAP with the DTMF codes
That all seem like too much? Then go to broadband reports.com and PM DogFace05 - he can remotely unlock your 2102, but there's a fee.
SOURCE: Samsung Juke resetting: "Power Cycle" leaves phone useless STILL
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
SOURCE: i have nokia 1280 but
Try this one,
http://www.filestube.com/3nudIQG0jqlaDC21HD7fjn/nokia-1280-hardware-solution.html
